Already make i.MX28 EVK work by Yocto Sato UI build.
But USB keyboard and mouse can't work in this board. Both of them plug in J81 USB host port .
Do some check below
***** USB driver looks work by dmesg check *****
root@imx28evk:~# dmesg |grep usb | |
usb DR wakeup device is registered | |
IMX usb wakeup probe | |
usbcore: registered new interface driver usbfs | |
usbcore: registered new interface driver hub | |
usbcore: registered new device driver usb | |
usb h1 wakeup device is registered | |
usbcore: registered new interface driver usb-storage | |
usbcore: registered new interface driver hiddev | |
usbcore: registered new interface driver usbhid | |
usbhid: USB HID core driver ***** Only find USB hub work by lsusb check ***** | |
root@imx28evk:~# lsusb | |
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub | |
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub |
Any idea to do USB keyboard/mouse check?
Solved! Go to Solution.
It work and problem gone.
1. Be master branch in repo
2. S16 set to WALL5V
Thomas, please click Correct Answer if your issue is gone.
Yixing
Yes.
Poky was recently updated and we faced the same issue you described.
It's caused by some evdev update/change. I was not able to figure out exactly what changed, but some previous configuration is not applicable with new evdev version.
Please, remove your tmp folder and pseudodone and make your image again. After that I had my mouse working again.
(and please, let me know the results)
