i.MX233 board USB not detected on win 7
PramodKumar
I have designed a i.MX233 board. It is working fine on RS232 port gives the message 0x8020A14 same in evaluation board without SD card.
When we insert linux OS SD card it gives message on RS232 0x8020A007 point to SD CONFIG BLOCK NOT FOUND.
I am using new i.MX233 controller and need to burn OTP for SD card boot.
I am unable to detect my board on PC. On PC USB details shows VID 000 &PID 0000 ( Unknown Device).
Pramod Kumar
SergioSolis
Hello Pramod,
Can you please try using the driver located in V2 of the Manufacturing Tool?... you can find the software here:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6Q&nodeId=018rH3ZrDRB24A&fpsp=1&t...
Under "Programmers (Flash, etc.)"
Inside you will find a "drivers" folder, please try it with that driver.
