i.MX21 EIM correct wait clocks
Search instead for
norishinozaki
I would like to determine wait cycles in EIM in i.MX21.
I'm setting WWS=0, WSC=111110 checking with MC9328MX21RM Rev.3, however it's not clear which is correct clocks, 63 or 62.
In the RM,
  Table 20-6. 63 clocks: "WSC=111110 results in 63 clock transfers"
  Table 20-7. 62 clocks: "WSC=111110 WWS=0 Read Access 62"
In the 20-7, 63 is Reserved so 62 is the corrcect clocks?
Nori Shinozaki
Tags (4)
Hi Nori
correct description is given in  Table 20-6 :
"WSC=111110 results in 63 clock transfers",
that is WSC encoded data results in +1 number of wait-states:
WSC = 000001 results in 2 clock transfers
WSC = 001110 results in 15 clock transfers
WSC = 111110 results in 63 clock transfers
MC9328MX21 3.19.1 EIM External Bus Timing Diagrams
gives examples.
Hi Nori
gives examples.
norishinozaki
Hello Igor,
Let me confirm, you mean the table value is typo.
The below is the correct one.
Right?
Nori Shinozaki
Hi Nori
yes this is right.
norishinozaki
Igor,
Thanks!
Nor! Shinozaki
norishinozaki
Hello Igor,
Thanks!
Nori Shinozaki
