Does the RT595 SDK provide MIPI driver? Where can I find the MIPI APP demo?
Looking forward to reply.
Solved! Go to Solution.
Hi @Dave_SU ,
You are welcome!
If your question is solved, please help to mark the correct answer, just to close this case.
Any new issues, welcome to create the new question post.
Kerry
Hi @Dave_SU ,
Please check the SDK code:
\SDK_2_11_1_EVK-MIMXRT595\boards\evkmimxrt595\driver_examples\lcdif\rgb565
This demo can support the fsl_mipi_dsi driver.
Wish it helps you!
Kerry
Hi @kerryzhou
Thanks a lot.
Hi @Dave_SU ,
You are welcome!
Kerry
