Hi @carloswei ,
You mean, the key files generated can't be used in the PC, but it is in the system?
Key files with private keys will be generated in the AN13250_SW\tools\blhost_upload\utils\evkmimxrt1170\cst\keys folder.
Can you run the cst in your company's HSM directly, then just need to use the SPT generate the encrypted image, then you can download it.
If the cst generated key file can't be used, it may have issues.
BTW, next time, please use the company email to create the case, it will have higher priority, thanks.
Kerry
