I tried the Secure Boot of I.MX 8mm. When looking at the information, I saw "config_secure_boot" and "config_imx_hab", and there were Guide documents under U-Boot/DOC: doc/imx/ahab/ doc/imx/habv4/
What is the difference between HABv4 and aHAB?
Is there a more detailed explanation document?
Solved! Go to Solution.
Hi @callme_friend,
I hope you are doing well.
CONFIG_SECURE_BOOT option is replaced with CONFIG_IMX_HAB in the newer BSP using the below commit.
Hi @callme_friend,
