Is it possible to boot from QSPI on NXP i.MX 8M EVK board MCIMX8M-EVK? Schematics file says "QSPI boot is not supported by ROM". If yes, what will be the Boot switch configuration? Regards Peter Gabor
Solved! Go to Solution.
Hi Peter
not, sorry, as described in sect.6.1 System Boot i.MX 8M Dual/8M QuadLite/8M Quad Applications Processors Reference Manual
The boot ROM supports these boot devices:
• NAND flash
• SD/MMC
Hi Peter
• NAND flash
• SD/MMC
