i.MX 8M Plus - Hardware Developper Guide (IMX8MPHDG Rev 1) - 32.768kHz Crystal Drive Level
Dan1111
The i.MX 8M Plus EVK (8MPLUSLPD4-CPU)uses ABS07-32768KHZ-T for the 32.768KHz crystal oscillator which as a typical drive level of 0.1µW and a maximum of 0.5µW.
However, Table 9 in the Hardware Developer's Guide (IMX8MPHDG Rev 1) states that the crystal requires a drive level of at least 1µW. Is this requirement a typo, and is it meant to say 0.1µW ?
Dan1111
Thanks Rita,
Isn't that the old Hardware Developers Guide revision?
You attached
IMX8MPHDG Rev 0, 03/2021, which says the drive strength must be at least 0.5µW.
I have
IMX8MPHDG Rev 1, 03/2024, which says drive strength must be at least 1µW.
https://www.nxp.com/webapp/Download?colCode=IMX8MPHDG
Rita_Wang
Yes, I attach old one for our rerence design, in your new design please follow the newest version. Thanks
any questions contact us freely
Dan1111
In that case, is the 1µW minimum drive level correct?
Rita_Wang
Yes, it is correct, please refer to the newest guide. Any questions contact me freely.
Rita_Wang
I think you need to download the newest guide document:
I attach it to you.
