Hello
When I execute `bitbake fsl-image-af-littlekernel`, I see `fsl-image-af-littlekernel-imx8mnddr4ab2-20210812083720.rootfs.wic.bz2`
but, If I re-execute `bitbake fsl-image-af-littlekernel` at same console.
bryanhong@sombra:build_imx8mnddr4ab2$ bitbake fsl-image-af-littlekernel
Loading cache: 100% |###################################################################################################| Time: 0:00:00
Loaded 4671 entries from dependency cache.
ERROR: Nothing PROVIDES 'fsl-image-af-littlekernel'
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
So,
1. I wonder why this is happening.
2. How do I make `fsl-image-af-littlekernel-imx8mnddr4ab2-20210812083720.rootfs.wic.bz2`
thanks
Bryan
Solved! Go to Solution.
I will ask you again by arranging the build issues for
