VPU wrapper library provides encoding and decoding functions of streams for VPUs with library interfaces such as the
Hantro VPU on the i.MX 8M family, if you just want to change the vpu parameter though vpu api, you can use unit test which has special vpu test module, gstreamer can send parameter to the vpu, like encoding or decoding format, width, height and so on
