In the datasheet of the i.MX 6UltraLite, for the 9x9 mm, 0.5 mm Pitch package the pin NVCC_DRAM_2P5 is in the position K6 and in the Table 93 is in the N6 position.
Could you clarify the position of the pin?
Thank you very much in advance.
Ricardo F.
The correct ball number for NVCC_DRAM_2P5 is K6.
(Documentation correction request has been submitted)
Yuri
