i.MX 6UL/ULL hardware trigger mode of ADC
1,604件の閲覧回数
sugiyamatoshihi
Contributor V
How to use i.MX6ULL ADC hardwear trigger mode in Reference Manual?
Does hardware trigger mode of ADC is only for touch screen?
If not, Please advice how to use  hardwear trigger mode for another usage?
Sugiyama
5 返答(返信)
1,377件の閲覧回数
igorpadykov
Hi Sugiyama
hardware triggering is not supported on the ADC i.MX6UL and 6ULL.
1,378件の閲覧回数
sugiyamatoshihi
Contributor V
Hi, Igor,
Thank you for reply.
Do you mean hardwear trigger is only for touch screen?
There is a description of touch screen in reference manual Chapter 54 Touch Screen Controller (TSC).
Sugiyama
1,378件の閲覧回数
igorpadykov
Hi Sugiyama
not touch screen,
Confirmed by application team.
1,378件の閲覧回数
sugiyamatoshihi
Contributor V
Hi ,Igor,
Thank you.
However, i.MX6UL/ULL support touch screen function with ADC. Is it right?
Sugiyama
1,378件の閲覧回数
igorpadykov
Hi Sugiyama
answer was provided for ADC hardware trigger.
Touch screen function with ADC is supported.
Touch screen function with ADC hardware trigger is not supported.
From sect.51.2.2.5 ADC-TSC co-working i.MX6UL Reference Manual :
"TSC starts ADC :
TSC sends two signals: trigger and hardware trigger select signal: HWTS[4:0]."
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
