hsm_import_key returns with 0xF0 (Bad Signature)
899 次查看
HH_Mov
During the "import key" of a custom generated keyblob, the response is: 0xF0
SAB reports (Invalid TLV signature)
SAB Error: SAB CMD [0x4f] Resp [0xf029] - Unknown error code
The used signature calculation is based on the OEM_IMPORT_CMAC_SK key, using the sample code from point 6 in "OEM Key import test flow".
Question 1: How can I verify if it is actually the signature going wrong and not e.g. using an invalid/incorrect OEM_IMPORT_CMAC_SK ?
There is an example tlv buffer in the documentation on page 219, but the used OEM_IMPORT_WRAP_SK, OEM_IMPORT_CMAC_SK (and the used imported key) are not provided, so I cannot verify this.
Question 2: If the OEM_IMPORT_CMAC_SK is wrong/mismatching on Peer and FW, how to debug?
482 次查看
HH_Mov
Issue was fixed. The problem was related to an incorrect fuse_version specified in the yaml file.
Why it was not 0 but 2 is not completely clear but it solved this issue
6 回复数
483 次查看
HH_Mov
851 次查看
Harvey021
There is demo related to the key import for your reference.
hope the ele-apps can help. also, the one smw-apps
Harvey
819 次查看
HH_Mov
Hello @Harvey021 ,
Thanks for the example, the imx-ele-apps/key-import, helped me verify my implementation, verifying the following are correct:
- NXP product manufact key agreement
- shared secret
- OEM_IMPORT_MK_SK
- OEM_IMPORT_WRAP_SK
- OEM_IMPORT_CMAC_SK
However performing the key-exchange (with the example SW) on an OEM_Closed device crashes the system:
sh run_test_on_board.sh
nxp_prod_ka_puk.bin exists.
oem_public_key.pem exists.
signed_msg.bin exists.
Hello, World! Sep 11 2025:14:50:25 77be1e7
Signed Message: 736 bytes
00e002890200000000000000b[  281.271513] fsl-se-fw se-fw2: Rx-Msg(0xe1470206): Fatal abort received  by hsm1.
Running the same test (with the example SW) on an OEM_Open device results in a invalid signature message:
    hsm_open_session success
    hsm_open_key_store_service success
    hsm_open_key_management_service success
    SAB Error: SAB CMD [0x47] Resp [0x1829] - Invalid Signature in SIGNED message.
    hsm_key_exchange failed err:0xfe
    Key exchange failed: 254
For info, the SRK hash reported by the signed message generation (running the command.sh on host side) for KEY_EXCHANGE_REQ matches the SRKH obtained from the HSM.
1. Is there an expected difference between an OEM_Open and OEM_Closed device ?
2. Why would the signature be reported invalid in the example ?
773 次查看
Harvey021
Hello @HH_Mov
For the 1st question, we'll further check with Internal R&D and get back to you.
For the 2nd question, we cannot reproduce the issue with the provided demo app. If possible, we can have a meeting with you to review your operations.
Harvey
740 次查看
HH_Mov
Hello Harvey,
Thanks for your reply. To validate our steps a colleague also tried the steps from the example and came to the same issues.
I would like to have a meeting to see if we can tackle this issue, maybe it is better to continue this via e-mail ?
Thnx
692 次查看
Harvey021
Hello @HH_Mov
With checking internal team, a meeting would be more effective in solving this problem. Please let us know from there.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2163777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehsm_import_key%20%E8%BF%94%E5%9B%9E%200xF0%EF%BC%88%E7%AD%BE%E5%90%8D%E9%94%99%E8%AF%AF%EF%BC%89%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%22%E5%AF%BC%E5%85%A5%E8%87%AA%E5%AE%9A%E4%B9%89%E7%94%9F%E6%88%90%E7%9A%84%E9%94%AE%E7%90%83%E7%9A%84%E5%AF%86%E9%92%A5%22%20%E6%97%B6%EF%BC%8C%E5%93%8D%E5%BA%94%E4%B8%BA0xF0%3C%2FP%3E%3CP%3ESAB%20%E6%8A%A5%E5%91%8A%EF%BC%88%E6%97%A0%E6%95%88%20TLV%20%E7%AD%BE%E5%90%8D%EF%BC%89%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3ESAB%20Error%3A%20SAB%20CMD%20%5B0x4f%5D%20Resp%20%5B0xf029%5D%20-%20Unknown%20error%20code%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E7%AD%BE%E5%90%8D%E8%AE%A1%E7%AE%97%E5%9F%BA%E4%BA%8E%20OEM_IMPORT_CMAC_SK%20%E5%AF%86%E9%92%A5%EF%BC%8C%E4%BD%BF%E7%94%A8%22OEM%20%E5%AF%86%E9%92%A5%E5%AF%BC%E5%85%A5%E6%B5%8B%E8%AF%95%E6%B5%81%E7%A8%8B%22%20%E4%B8%AD%E7%AC%AC%206%20%E7%82%B9%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3E%E9%97%AE%E9%A2%98%201%3C%2FU%3E%EF%BC%9A%20%E5%A6%82%E4%BD%95%E9%AA%8C%E8%AF%81%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E6%98%AF%E7%AD%BE%E5%90%8D%E5%87%BA%E9%94%99%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BD%BF%E7%94%A8%E4%BA%86%E6%97%A0%E6%95%88%2F%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%20OEM_IMPORT_CMAC_SK%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%96%87%E6%A1%A3%E7%AC%AC%20219%20%E9%A1%B5%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%B8%AA%20tlv%20%E7%BC%93%E5%86%B2%E5%8C%BA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E4%BD%BF%E7%94%A8%E7%9A%84%20OEM_IMPORT_WRAP_SK%E3%80%81OEM_IMPORT_CMAC_SK%EF%BC%88%E4%BB%A5%E5%8F%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E5%AF%BC%E5%85%A5%E5%AF%86%E9%92%A5%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%97%A0%E6%B3%95%E9%AA%8C%E8%AF%81%E3%80%82%3C%2FP%3E%3CP%3E%3CU%3E%E9%97%AE%E9%A2%98%202%EF%BC%9A%3C%2FU%3E%E5%A6%82%E6%9E%9C%20Peer%20%E5%92%8C%20FW%20%E4%B8%8A%E7%9A%84%20OEM_IMPORT_CMAC_SK%20%E9%94%99%E8%AF%AF%2F%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%8C%E5%A6%82%E4%BD%95%E8%B0%83%E8%AF%95%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%B7%B2%E8%A7%A3%E5%86%B3%E3%80%82%E9%97%AE%E9%A2%98%E4%B8%8E%20yaml%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%8C%87%E5%AE%9A%E7%9A%84%20fuse_version%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E6%9C%89%E5%85%B3%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E6%98%AF%200%EF%BC%8C%E8%80%8C%E6%98%AF%202%EF%BC%8C%E8%BF%98%E4%B8%8D%E5%AE%8C%E5%85%A8%E6%B8%85%E6%A5%9A%EF%BC%8C%E4%BD%86%E5%AE%83%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252198%22%20target%3D%22_blank%22%3E%40HH_Mov%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%9C%A8%E6%A3%80%E6%9F%A5%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E6%97%B6%EF%BC%8C%E5%8F%AC%E5%BC%80%E4%BC%9A%E8%AE%AE%E4%BC%9A%E6%9B%B4%E6%9C%89%E6%95%88%E5%9C%B0%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E8%AF%B7%E4%BB%8E%E9%82%A3%E9%87%8C%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%93%88%E7%BB%B4%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%E4%B8%BA%E4%BA%86%E9%AA%8C%E8%AF%81%E6%88%91%E4%BB%AC%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%B8%80%E4%BD%8D%E5%90%8C%E4%BA%8B%E4%B9%9F%E5%B0%9D%E8%AF%95%E4%BA%86%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E5%B9%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%8F%AC%E5%BC%80%E4%B8%80%E6%AC%A1%E4%BC%9A%E8%AE%AE%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B9%9F%E8%AE%B8%E9%80%9A%E8%BF%87%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E7%BB%A7%E7%BB%AD%E8%AE%A8%E8%AE%BA%E6%9B%B4%E5%A5%BD%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2169583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2169583%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252198%22%20target%3D%22_blank%22%3E%40HH_Mov%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E7%AC%AC%201%20%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%90%91%E5%86%85%E9%83%A8%20R%26amp%3BD%20%E8%AF%A2%E9%97%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E7%BB%99%E6%82%A8%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%E6%89%80%E6%8F%90%E4%BE%9B%E7%9A%84%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%87%8D%E7%8E%B0%E8%AF%A5%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%B8%8E%E6%82%A8%E4%BC%9A%E9%9D%A2%EF%BC%8C%E5%AE%A1%E6%9F%A5%E6%82%A8%E7%9A%84%E8%BF%90%E8%90%A5%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192970%22%20target%3D%22_blank%22%3E%40Harvey021%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E6%8F%90%E4%BE%9B%E7%9A%84%20imx-ele-apps%2Fkey-import%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%AE%83%E5%B8%AE%E5%8A%A9%E6%88%91%E9%AA%8C%E8%AF%81%E4%BA%86%E6%88%91%E7%9A%84%E5%AE%9E%E7%8E%B0%EF%BC%8C%E7%A1%AE%E8%AE%A4%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E6%81%A9%E6%99%BA%E6%B5%A6%E4%BA%A7%E5%93%81%E5%88%B6%E9%80%A0%E5%AF%86%E9%92%A5%E5%8D%8F%E8%AE%AE%3CBR%20%2F%3E-%20%E5%85%B1%E4%BA%AB%E7%A7%98%E5%AF%86%3CBR%20%2F%3E-%20OEM_IMPORT_MK_SK%3CBR%20%2F%3E-%20OEM_IMPORT_WRAP_SK%3CBR%20%2F%3E-%20OEM_IMPORT_CMAC_SK%3C%2FP%3E%3CP%20class%3D%22lia-align-left%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%20OEM_Closed%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%89%A7%E8%A1%8C%E5%AF%86%E9%92%A5%E4%BA%A4%E6%8D%A2%EF%BC%88%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%20SW%EF%BC%89%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%B3%BB%E7%BB%9F%E5%B4%A9%E6%BA%83%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esh%20run_test_on_board.sh%0Anxp_prod_ka_puk.bin%20exists.%0Aoem_public_key.pem%20exists.%0Asigned_msg.bin%20exists.%0AHello%2C%20World!%20Sep%2011%202025%3A14%3A50%3A25%2077be1e7%0ASigned%20Message%3A%20736%20bytes%0A00e002890200000000000000b%5B%20%20281.271513%5D%20fsl-se-fw%20se-fw2%3A%20Rx-Msg(0xe1470206)%3A%20Fatal%20abort%20received%20%20by%20hsm1.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%20OEM_Open%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%88%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%20SW%EF%BC%89%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%AD%BE%E5%90%8D%E6%B6%88%E6%81%AF%E6%97%A0%E6%95%88%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20hsm_open_session%20success%0A%20%20%20%20hsm_open_key_store_service%20success%0A%20%20%20%20hsm_open_key_management_service%20success%0A%0A%20%20%20%20SAB%20Error%3A%20SAB%20CMD%20%5B0x47%5D%20Resp%20%5B0x1829%5D%20-%20Invalid%20Signature%20in%20SIGNED%20message.%0A%0A%20%20%20%20hsm_key_exchange%20failed%20err%3A0xfe%0A%20%20%20%20Key%20exchange%20failed%3A%20254%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%AD%BE%E5%90%8D%E4%BF%A1%E6%81%AF%E7%94%9F%E6%88%90%EF%BC%88%E5%9C%A8%E4%B8%BB%E6%9C%BA%E7%AB%AF%E8%BF%90%E8%A1%8C%20command.sh%EF%BC%89%E6%8A%A5%E5%91%8A%E7%9A%84%20KEY_EXCHANGE_REQ%20%E7%9A%84%20SRK%20%E5%93%88%E5%B8%8C%E5%80%BC%E4%B8%8E%E4%BB%8E%20HSM%20%E8%8E%B7%E5%8F%96%E7%9A%84%20SRKH%20%E4%B8%80%E8%87%B4%E3%80%82%3C%2FP%3E%3CP%3E1%E3%80%82OEM_Open%20%E5%92%8C%20OEM_Closed%20%E8%AE%BE%E5%A4%87%E4%B9%8B%E9%97%B4%E6%9C%89%E9%A2%84%E6%9C%9F%E7%9A%84%E5%8C%BA%E5%88%AB%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E2.%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E4%BC%9A%E6%8A%A5%E5%91%8A%E7%AD%BE%E5%90%8D%E6%97%A0%E6%95%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20hsm_import_key%20returns%20with%200xF0%20(Bad%20Signature)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%B8%8E%E5%AF%86%E9%92%A5%E5%AF%BC%E5%85%A5%E7%9B%B8%E5%85%B3%E7%9A%84%E6%BC%94%E7%A4%BA%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fimx_sec_apps%2Ftree%2Fmaster%2Fimx-ele-apps%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eele-apps%3C%2FA%3E%E8%83%BD%E5%B8%AE%E4%B8%8A%E5%BF%99%E3%80%82%E8%BF%98%E6%9C%89%EF%BC%8C%E9%82%A3%E4%B8%AA%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fimx_sec_apps%2Ftree%2Fmaster%2Fimx-smw-apps%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esmw-apps%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
