Hi, All
Try to use Freescale Yocto Project on imx6sx-SDB,and following <Freescale Yocto Project User's Guide>, but fail to see imx6sxsabresd with "source setup-environment". What should I do to setup proper environment for developing imx6sx. Thanks!
zhl-ce8@ubuntu:~/fsl-release-bsp$ source setup-environment
Usage: source setup-environment <build-dir>
<build-dir>: specifies the build directory location (required)
If undefined, this script will set $MACHINE to 'imx6qsabresd'.
Supported machines:
imx23evk
imx28evk
imx31pdk
imx35pdk
imx51evk
imx53ard
imx53qsb
imx6dlsabreauto
imx6dlsabresd
imx6qsabreauto
imx6qsabresd
imx6slevk
imx6solosabreauto
imx6solosabresd
ls1021aqds
ls1021atwr
twr-vf65gs10
cfa10036
cfa10037
cfa10049
cfa10055
cfa10056
cfa10057
cfa10058
cgtqmx6
cubox-i
imx233-olinuxino-maxi
imx233-olinuxino-micro
imx233-olinuxino-mini
imx233-olinuxino-nano
imx6dl-riotboard
imx6qsabrelite
m28evk
m53evk
nitrogen6x
nitrogen6x-lite
pcl052
pcm052
quartz
wandboard-dual
wandboard-quad
wandboard-solo
To build for a machine listed above, run this script as:
MACHINE=<machine> source setup-environment <build-dir>
Cheng Shi
emtronix
