Hi all,
I want to enable wps when i am entering into the hotspot on android6.
For this i enable wps configuration on that android configuration file.
Can anyone give support to work on wps on hotspot .
And how to connect my android6(wps server) with speaker(wps client) by using wps button.
已解决! 转到解答。
Dear Nxp,
Thank you for your support. Sorry for my late reply, actually I have done this configuration.
Needs to add the string (wps_state, eap_server) in the following files,
system/netd/server/SoftapController.cpp
int SoftapController::setSoftap(int argc, char *argv[]) {
int hidden = 0;
int channel = AP_CHANNEL_DEFAULT;
int wps_state = 2;
if (argc < 5) {
ALOGE("Softap set is missing arguments. Please use:");
ALOGE("softap <wlan iface> <SSID> <hidden/broadcast> <channel> <wpa2?-psk|open> <passphrase>");
return ResponseCode::CommandSyntaxError;
if (!strcasecmp(argv[4], "hidden"))
hidden = 1;
if (argc >= 5) {
channel = atoi(argv[5]);
if (channel <= 0)
std::string wbuf(StringPrintf("interface=%s\n"
"driver=nl80211\n"
"ctrl_interface=/data/misc/wifi/hostapd\n"
"ssid=%s\n"
"channel=%d\n"
"ieee80211n=1\n"
"hw_mode=%c\n"
"ignore_broadcast_ssid=%d, eap_server = 1, wps_state = %d\n",
argv[2], argv[3], channel, (channel <= 14) ? 'g' : 'a', hidden,wps_state));
std::string fbuf;
if (argc > 7) {
char psk_str[2*SHA256_DIGEST_LENGTH+1];
if (!strcmp(argv[6], "wpa-psk")) {
if (!generatePsk(argv[3], argv[7], psk_str)) {
return ResponseCode::OperationFailed;
fbuf = StringPrintf("%swpa=3\nwpa_pairwise=TKIP CCMP\nwpa_psk=%s\n", wbuf.c_str(), psk_str);
} else if (!strcmp(argv[6], "wpa2-psk")) {
fbuf = StringPrintf("%swpa=2\nrsn_pairwise=CCMP\nwpa_psk=%s\n", wbuf.c_str(), psk_str);
} else if (!strcmp(argv[6], "open")) {
fbuf = wbuf;
} else if (argc > 6) {
fbuf = wbuf;
} else {
fbuf = wbuf;
if (!WriteStringToFile(fbuf, HOSTAPD_CONF_FILE, 0660, AID_SYSTEM, AID_WIFI)) {
ALOGE("Cannot write to \"%s\": %s", HOSTAPD_CONF_FILE, strerror(errno));
return ResponseCode::SoftapStatusResult;
Testing,
hostapd_cli wps_pbc
VinothS
Dear Nxp,
int hidden = 0;
int wps_state = 2;
if (argc < 5) {
hidden = 1;
if (argc >= 5) {
if (channel <= 0)
"driver=nl80211\n"
"ssid=%s\n"
"channel=%d\n"
"ieee80211n=1\n"
"hw_mode=%c\n"
std::string fbuf;
if (argc > 7) {
fbuf = wbuf;
fbuf = wbuf;
} else {
fbuf = wbuf;
Testing,
hostapd_cli wps_pbc
VinothS
In our BSP, you can find an application called Ethernet. In that application, you have all the google tools to set the hotspot on your device.
I hope this can solve your problem.
Diego.
Thanks Diego,
But, I get little confuse. Why because, In my board hotspot working fine. I want to add option for WPS button or i want to call that WPI internally.
Thanks and Regards,
VinothS.
Thanks Diego,
I found that Ethernet Application.
And i don't know how to use that Ethernet Application for wps in hotspot.
Is there any separate TV setting in that BSP.?
We are make it call the wps start in that tethering function but i don't get any response.
With Regards,
VinothS,
