Hello, now the problem has been close to the solution stage, I try to modify the configuration parameters in the u-boot-2009.08/include/configs/mx6q_sabresd.h now, so that you can boot from the SD3 into the kernel rather than through the network, but I F:\imx6q\2014_5_3\imx6q_softwae\ L3.0.35_4.1.0_130816_source\L3.0.35_4.1.0_130816_source\pkgs\u-boot-2009.08.tar.bz2 not found in the mx6q_sabresd.h file, please tell me where I can find this file
Thank you
在 2014-08-22 12:33:58,"Yuri Muhin" <admin@community.freescale.com> 写道:
how to use the 12_09_01_oneiric file Ubuntu63 file, I want to use the Ubuntu in the SDB development board
reply from Yuri Muhin in i.MX Community - View the full discussion
Looks like U-boot automatically starts NFS-based boot.
Please re-configure U-boot environment as needed, using
section 7.2 (Downloading Images by U-Boot) of
"i.MX_6Dual6Quad_SABRE-SD_Linux_User's_Guide.pdf"
~Yuri.
Reply to this message by replying to this email, or go to the message on Freescale Community |
Start a new discussion in i.MX Community by email or at Freescale Community |
Following how to use the 12_09_01_oneiric file Ubuntu63 file, I want to use the Ubuntu in the SDB development board in these streams: Inbox |
