how to use OpenCV in Yocto
2,197 次查看
Mahyar
Hi All,
I'm using Boundary Devices' SabreLite with a Mipi camera (Ov5460) with Yocto distribution dora branch.
I created the fsl-image-gui and also built opencv and opencv-samples using bitbake.
Mipi camera works correctly itself (gst-launch mfw_v4lsrc capture-mode=5 ! mfw_v4lsink)
now how can I use opencv on Yocto? (I can see opencv in /usr/share)
how can I use a simple test to see if openCV works correctly?
any suggestions would be great.
TIA
1,558 次查看
andre_silva
You can follow the instruction I posted in this blog:
http://imxcv.blogspot.com.br/2014/02/building-opencv-24x-for-freescales-imx6.html
regards,
Andre
1,558 次查看
jamesbone
We have this Application Note regarding OpenCV.
http://cache.freescale.com/files/32bit/doc/app_note/AN4629.pdf
