Hi , we use btbake command to built the v2018.03 of uboot and got below files. As i know, u-boot file is .imx or .bin.
how i can to transfer files to imx ?
thanks.
You can Compling u-boot & linux kernel under Stanalone , no need to transfer. As Kunal said above you can refer to .
Hi hankwang,
What are the steps you are using to generate the u-boot.img? However, I assume you are using Yocto for generating an image for i.MX6Quad. For building the u-boot there are two ways:
For your reference I have attached the documents considering L4.14.98-2.0.0_ga BSP. If your are using another BSP then you can download the documents from i.MX Software and Development Tools | NXP .
Please let me know if you face any further issue.
Kunal
