how to set LVDS output data to 8bit
1,773 次查看
pfsang
hi , all
      as my LVDS panel supports 8bit lvds input data, i should set lvds ouput data to 8bit.
      could you tell me how to set it?
thanks
peter
标签 (6)
1,454 次查看
Hi fang
if you means RGB24 (RGB888) ldb format then please at links below
iMX6QD How to Add 24-bit LVDS Support in Android
https://support.bluetechnix.at/wiki/Linux_Software_User_Manual_%28i.MX6%29#Display_Interfaces
chip
1,455 次查看
Hi fang
chip
