how to see the written address values in uboot for 36.4.38 Pad Mux Register (IOMUXC_SW_MUX_CTL_PAD_EIM_DATA22) Address: 20E_0000h base + A8h offset = 20E_00A8h
sumanthg
i had tired in uboot but unable to get the correct value
=> md 020e00a8h
020e00a8: 00000004 00000005 00000005 00000005    ................
020e00b8: 00000005 00000004 00000004 00000005    ................
020e00c8: 00000005 00000005 00000005 00000005    ................
020e00d8: 00000005 00000005 00000005 00000005    ................
020e00e8: 00000005 00000005 00000000 00000000    ................
020e00f8: 00000000 00000000 00000000 00000000    ................
020e0108: 00000005 00000000 00000000 00000000    ................
020e0118: 00000005 00000000 00000005 00000000    ................
020e0128: 00000000 00000005 00000005 00000005    ................
020e0138: 00000000 00000000 00000000 00000005    ................
020e0148: 00000005 00000005 00000005 00000005    ................
020e0158: 00000000 00000000 00000000 00000000    ................
020e0168: 00000000 00000000 00000000 00000000    ................
020e0178: 00000000 00000000 00000000 00000000    ................
020e0188: 00000000 00000000 00000000 00000000    ................
020e0198: 00000000 00000000 00000000 00000000    ................
Labels (4)
b36401
Accordingly to field descriptions the value 4 means regular mux mode and ALT4 usage - "select signal USB_OTG_PWR".
Victor
sumanthg
can this USB_OTG_PWR pin can act as a Output pin and supply voltage
