@gonewithwind-peter
Yes you can. Remove the top side.
clients\desktop-shell.c
static void
parse_panel_position(struct desktop *desktop, struct weston_config_section *s)
char *position;
//desktop->want_panel = 1;
desktop->want_panel = 0;
weston_config_section_get_string(s, "panel-position", &position, "top");
if (strcmp(position, "top") == 0) {
desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_TOP;
} else if (strcmp(position, "bottom") == 0) {
desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_BOTTOM;
} else if (strcmp(position, "left") == 0) {
desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_LEFT;
} else if (strcmp(position, "right") == 0) {
desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_RIGHT;
} else {
/* 'none' is valid here */
if (strcmp(position, "none") != 0)
fprintf(stderr, "Wrong panel position: %s\n", position);
free(position);
