how to remove xwayland desktop display in maaxboard zeus yocto image
1,241 次查看
gonewithwind-peter
Senior Contributor I
hi all,
for our application, we use chromium webpage as GUI for users to operate menu and display.
but there is a time gap between the wayland windows desktop display(the left top  side is terminal Icon, top right side is time) and our chrome page.
Can we remove the xwayland  windows desktop display? or remove terminal Icon and time display to make the background as  same color or a picture?
Thank you very much.
1,229 次查看
gonewithwind-peter
@Zhiming_Liu
thanks
1,234 次查看
Zhiming_Liu
@gonewithwind-peter
Yes you can. Remove the top side.
clients\desktop-shell.c
static void
parse_panel_position(struct desktop *desktop, struct weston_config_section *s)
	char *position;
	//desktop->want_panel = 1;
          desktop->want_panel = 0;
	weston_config_section_get_string(s, "panel-position", &position, "top");
	if (strcmp(position, "top") == 0) {
		desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_TOP;
	} else if (strcmp(position, "bottom") == 0) {
		desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_BOTTOM;
	} else if (strcmp(position, "left") == 0) {
		desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_LEFT;
	} else if (strcmp(position, "right") == 0) {
		desktop->panel_position = WESTON_DESKTOP_SHELL_PANEL_POSITION_RIGHT;
	} else {
		/* 'none' is valid here */
		if (strcmp(position, "none") != 0)
			fprintf(stderr, "Wrong panel position: %s\n", position);
	free(position);
