how to modify flash_header for DDR3 2GB
fangmingan
Based on mx6q_sabresd(default 1GB DDR3: 4x 2Gbit ddr3 chip, 64bit bus, only cs0 used  ), we want to change to 2GB DDR3, how to modify the flash_header.s
Thanks a lot
Original Attachment has been moved to: flash_header.S.txt.zip
TaniaMartinez
Hello, We have a i.Mx6Q DDR3 programming register tool. This is a tool can generate a DDR3 script easily for i.Mx6DQSDL and only need input several parameters based on using DDR datasheet and system architecture.
Please find i.Mx6Q DDR3 Script Aid through below link.
https://community.freescale.com/docs/DOC-94917
Tania
TaniaMartinez
Tania
