how to installing "segoe ui" fonts on to imx6qp yocto build
3,442 次查看
lavakumars
hi,
I am working on the imx6qp sabre AI board, with yocto build with kernel version 4.1.15.
Now I want to use the " segoe ui" fonts in my QT application please can someone help me how to use it.
on target just keeping the fonts directory is not useful.
Lavakumar S
3,014 次查看
lavakumars
hi Joan Xie,
Thanks for the reply.
That did not work me on target. but yes it worked when I did below steps.
1. kept the .ttf(fonts files) in a foder and
2. used the command below  before running the app
      export QT_QPA_FOTNDIR="folder/path/of/your/fonts"
its worked ok now for my hmi.
Lavakumar S
3,014 次查看
joanxie
did you have this fonts package? if yes, pls put this package to /usr/lib/fonts, then in the implayer to choose this character,
3,015 次查看
lavakumars
hi Joan Xie,
Lavakumar S
