how to get CPU id of imx8mm
已解决
跳至解决方案
5,716 次查看
jingyangxie
Contributor V
How can I get cpu id of imx8mm in bsp 5.4.70_2.3.2?
1 解答
5,667 次查看
BiyongSUN
If you read the code, you will find below for uuid
cat /sys/devices/soc0/soc_uid
5.10
cat /sys/devices/soc0/serial_number
在原帖中查看解决方案
4 回复数
5,702 次查看
joanxie
5,692 次查看
jingyangxie
Contributor V
Hi,Joanxie
    I mean to get cpu ids(or unique ids) in user-mode apps
5,668 次查看
BiyongSUN
5.10
5,673 次查看
joanxie
you can use the command as below:
fuse read 0 1
fuse read 0 2
You can also get the same values reading the OCOTP_HW_OCOTP_TESTER0 and OCOTP_HW_OCOTP_TESTER1 registers.
Commands are:
md.l 0x30350410 1
md.l 0x30350420 1
