how to fix omxplayer and nuplayer error.
lifusong
when boot into os  and type command logcat on debug console  will get below info.
E/OMXNodeInstance(  142): getParameter(100663311) ERROR: 0x8000100e
E/OMXNodeInstance(  142): getParameter(100663297) ERROR: 0x8000100e
E/OMXNodeInstance(  142): OMX_GetExtensionIndex OMX.google.android.index.storeMetaDataInBuffers failed
I/SoftMPEG4Encoder(  142): Construct SoftMPEG4Encoder
W/ACodec  (  142): do not know color format 0x7f000789 = 2130708361
I/SoftAVCEncoder(  142): Construct SoftAVCEncoder
I/ActivityManager(  417): Start proc com.android.phone for service com.android.mms.service/.MmsService: pid=678 uid=1001 gids={41001, 9997, 3002, 3001, 3003, 1028, 1015} abi=armeabi-v7a
W/VoiceInteractionManagerService(  417): no available voice interaction services found for user 0
W/VoiceInteractionManagerService(  417): no available voice recognition services found for user 0
E/NuPlayer(  142): feedDecoderInputData getCurrentPosition failed.
E/OMXMaster(  142): A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one.
E/OMXMaster(  142): A component of name 'OMX.Freescale.std.parser.streaming.sw-based' already exists, ignoring this one.
W/OMXNodeInstance(  142): OMX_GetExtensionIndex OMX.google.android.index.prepareForAdaptivePlayback failed
Labels (2)
Tags (2)
brianmuse
lifusong Was there ever a resolution to this issue?
lifusong
No,we can't fix this issue.
joanxie
what andrido version and what command do you use? pls give us more detailed information to fix this.
lifusong
Android 5.0
kernel 3.10.53
cpu imx6q
what command.
boot into android os
connect debug console(com4) with tool xshell,you will get the linux command line.
run command logcat
