Hi ,
I have maaxboard (i.MX8MQ) and maaxboard-mini (i.MX 8M Mini) for same product.
I disable dmesg in my system.
how to check which board I am in after bootup?
I try cat /proc/cupinfo, but can not find "MX8MQ"
where I can find the info ?
You can see it on boot, specifically on U-boot:
Also, when the kernel is starting:
Best regards.
Depends on BSP version.
ls /sys/devices/soc0/
family machine power revision serial_number soc_id subsystem uevent
cat /sys/devices/soc0/machine
FSL i.MX8MM EVK board
sorry, my question is not clear. I know how to check in uboot process. and use dmesg after linux is running.
but I disable dmesg output. my question which command in after linux is running (not in kernel startup process,not using dmesg) to find what the cpu is. I tried to use cat /proc/cpuinfo, but there was no microprocessor info.
