how to enable linux suspend to disk or MMC
1,988 次查看
sunyd
hi,
because need implement Low  power  consumption,and suspend to RAM unable tomeet needs,and suspend to disk or MMC should  be,but how do i configure linux kernel  to implement the feature
thank you!!!
标签 (1)
1 回复
1,826 次查看
Hi sunyd
unfortunately it is not supported in nxp bsps, one can try to implement
it using suggestions on:
Suspend To Disk For ARM - eLinux.org
https://community.nxp.com/docs/DOC-99733
