Recently I want to implement voice record and compressed with amr on i.mx28 linux platform. I saw the amr encoder library in /usr/lib, but has no gstreamer plugin for it. Does anyone konws how to enable amr plugin?
Solved! Go to Solution.
Freescale provides the decoder but not the encoder. Try installing bad and ugly set of gst-plugins and do a 'gst-inspect | grep amr'. As I can see, there is a SW AMR encoder that you may use
