how to disable the configuration option FB_MXC_VAR_WVGA_SYNC_PANEL
sarathithiru
I am using Imx 6 pico sbc with linux 3.035. i have interfaced my board with LVDS. but i am getting the screen as attached below.
screens are splitted in to 6 views
please get me some solution to solve this.
sarathi.T
Labels (3)
Aubineau_FAE
What is the resolution of your screen and what is the resolution of your framebuffer?
Does it match?
if not can you try the fbset command, for instance:
fbset -fb /dev/fb0 -g 1024 768 1024 2304 32
check resolution, fb number and bpp.
check also fbset manual:
fbset - Linux Command - Unix Command
V.
sarathithiru
i have rectified this error, by changing the display standard.
Thank you
