how to disable network initialization scripts (not to be bitbaked)
davidzhou
Contributor V
I have imx6ul development board.
 I have undefined network related CONFIG_...s and removed any network (ethernet and bluetooth) hardware device drivers, but the kernel recipes still bitbaked and network initialization scripts still run:
output from console:
Configuring network interfaces... ifconfig: socket(AF_INET,2,0): Function not implemented
I have added the following in the local.conf:
PACKAGECONFIG_remove += " network init-ifupdown "
But it is not working. Whatelse do I need?
Thank you,
David Zhou
