how to disable mouse cursor displaying in maaxboard( NXP i.MX 8M)yocto zeus wayland desktop?
9,162 次查看
gonewithwind-peter
Senior Contributor I
hi  all,
how to disable mouse cursor displaying in maaxboard yocto zeus wayland desktop?
we use touchscreen, do not use the mouse to operate the menu, but there is a  black arrow mouse   cursor  displaying on the desktop(our app is base on chrome webpage)
how to disable it?
Does anybody have any help?
Thank you.
11 回复数
9,149 次查看
gonewithwind-peter
@Zhiming_Liu
thanks
9,154 次查看
Zhiming_Liu
@gonewithwind-peter clients\window.c
    //create_cursors(d);
   // d->theme = theme_create();
9,130 次查看
gonewithwind-peter
@Zhiming_Liu
do you know where is the cursor  file location,  we can use a transparent  cursor file to replace the  black left arrow icon.
please read here:
https://github.com/celly/transparent-xcursor
but I  cann not find where the icon is !
read here ,I posted a issue: https://github.com/celly/transparent-xcursor/issues
9,122 次查看
Zhiming_Liu
@gonewithwind-peter
The weston didn't use cursor icon in default.
You can config cursor-theme like:cursor-theme=Adwaita in weston.ini
9,088 次查看
gonewithwind-peter
hi @Zhiming_Liu
as you said ,I add cursor-theme=Adwaita in weston.ini
and create a subfolder cursors in /usr/share/icons/Adwaita/cursors,
and copy a transparent cursor file from here https://github.com/celly/transparent-xcursor.  to  /usr/share/icons/Adwaita/cursors/ , for example: left_ptr file /usr/share/icons/Adwaita/cursors/left_ptr
Actually , the mouse cursor (black arrow) disappears in weston desktop! work! , so I change Adwaita to redglass (I copy from ubuntun desktop), actually the black arrow become RED arrow. so I make sure the solution is OK.
but our app is base on chromium(chromium-ozone-wayland )webpage. after chromium start up, the black arrow cursor comes again!
so I want to know where is the cursor icon's location displaying on  chromium?
I only create one file(left_ptr) in folder /usr/share/icons/Adwaita/cursors, where are the others? where the icons from on the chromium?
if I know the location,I can replace it with transparent files to make it disappear!
when I use  redglass Icons, it's red on weston destop,but it become black arrow again on chromium, so i thinks the icons are form different locations(files)
Thank you very much.
Does anyone know?
9,074 次查看
Zhiming_Liu
It seems that chrouim is different with weston about cursor display.I have no research about chrouim.
The change about removing top screen display is tested, but thr cursor i didn't test before.
9,066 次查看
gonewithwind-peter
@Zhiming_Liu
Thank you for your reply so soon.
I use   the following userspace code to move the cursor to left-lower corner to solve this problem. almsot is OK
https://unix.stackexchange.com/questions/422698/how-to-set-absolute-mouse-cursor-position-in-wayland...
标记 (1)
9,138 次查看
gonewithwind-peter
@Zhiming_Liu
I followed your guide to comments the tow lines in clients/windows.c
but weston   desktop totally  disappear,
my weston-chrome can not run and not display
any help?
the following is my weston.ini file config:
[core]
gbm-format=argb8888
idle-time=0
#use-g2d=1
#xwayland=true
#enable-overlay-view=1
[shell]
size=1920x1080
panel-location=""
panel-position=none
background-color=0x00000000
background-image=/home/myuser/flash.png
[libinput]
touchscreen_calibrator=true
#[output]
#name=HDMI-A-1
#mode=1920x1080@60
#transform=90
9,118 次查看
Zhiming_Liu
You can add a script that can boot chrome when system start.
9,100 次查看
gonewithwind-peter
hi @Zhiming_Liu
it seems I change the file clients\window.c , damage the whole weston, so can not rum wayland-chromium,
is it right?
did you test that before to modify the file clients\window.c?
thanks
9,104 次查看
gonewithwind-peter
yes, I used a script (chromium.service in systemd) to boot chrome. but  after comment the cursor source code, weston desktop windows disappear, nothing to display.
let me try cursor-theme=Adwaita
