how to disable chromium update notice to popping up?
gonewithwind-peter
Senior Contributor I
Hi all,
I use imx8 maaxboad,iwave board. we use chromium  -kiosk  webpage  as user GUI(of course ,there is no menu,no settings ...(3 points ),no webpage bar....
but the  chromium  keep popping up update  notice to dispplay. how to disable it  when starting  up chromium with options or in setting config files in somewhere? (of course , can not use menu to change it manually).
I searched online, but do not find solutions  up to now.
any help?
Thank you very much.
gonewithwind-peter
The following are the relevant flags we set. Of these, the --simulate-outdated-no-au argument is the one you need for this issue, but we specify a bunch more to suppress behaviour that assumes a user present or is otherwise desirable in a kiosk.
exec /usr/bin/chromium \
  --kiosk --enable-fullscreen \
  --touch-events=enabled \
  --activate-on-launch \
  --noerrdialogs \
  --remote-debugging-port=9222 \
  --disable-pinch \
  --disable-features=OverscrollHistoryNavigation \
  --start-maximized \
  --disable-infobars \
  --disable-notifications \
  --disable-session-crashed-bubble \
  --no-first-run \
  --enable-offline-auto-reload \
  --autoplay-policy=no-user-gesture-required \
  --deny-permission-prompts \
  --disable-search-geolocation-disclosure \
  --enable-ipv6 $CHROMIUM_EXTRAS \
  --simulate-outdated-no-au='Tue, 31 Dec 2099 23:59:59 GMT' \
  --disable-component-update \
  --allow-browser-signin=false \
  "${KIOSK_URI}"
gonewithwind-peter
  --noerrdialogs \
  --disable-pinch \
  --start-maximized \
  --no-first-run \
  "${KIOSK_URI}"
Zhiming_Liu
@gonewithwind-peter
Did you try add this :–disable-desktop-notifications ?
gonewithwind-peter
@Zhiming_Liu
I add that option, but not work.
can I remove the message from the source code?
I find the message at file :
./tmp-glibc/work/aarch64-oe-linux/chromium-x11/76.0.3809.100-r0/chromium-76.0.3809.100/chrome/app/chromium_strings.grd
but I not not sure how to remove it.
anybody any help?
gonewithwind-peter
@Zhiming_Liu
let me try to add it , thanks
