how to configure mux and gpios
3,425 次查看
sadasivam
How to access gpio from user space, i have sabre-sdb EVB. kindly point some documents/datasheets, it will be helpful for me.
Sada
标签 (2)
2,843 次查看
AnsonHuang
     for DL, it is in arch/arm/mach-mx6/board-mx6dl_sabresd.h, for i.MX6Q, it is arch/arm/mach-mx6/board-mx6q_sabresd.h. You need to set the intial status of all pins.
5 回复数
2,843 次查看
AnsonHuang
Hi, Sada
     From linux Document, Documentation/gpio.txt, it will tell how to control a GPIO from userspace.
2,843 次查看
sadasivam
The below GPIO has been configured as used as LED in the EVB.
#define SABRESD_USR_DEF_RED_LED    IMX_GPIO_NR(1, 2)
when i tried to export the same as per GPIO.txt
getting below error
echo 2 > export
sh: write error: Device or resource busy
I also tried with another GPIO3[15].
which is already set as Input. I am able to change direction of that particular pin. but not able to make changes in value. Value always remains 0.
what am i missing to do????
2,843 次查看
AnsonHuang
You may need to check this pin's IOMUX, normally it is not set as GPIO mode. And GPIO driver will not handle the MUX setting.
2,843 次查看
sadasivam
I tried to find how to change the MUX mode in target board, but didnt find any details.  Kindly advice how to check/modify the IO mux. Can it be changed after login??
2,844 次查看
AnsonHuang
