how to config deviceTree to output CLKO1 in imx7d
1,165件の閲覧回数
hyoungkikim
hi commuity
on my custom board   i like to  use CLKO1 as a referece clk of a slave device
i searched commuity and  i  found   it can be done in devicetree  with assigned-clock
but i don't find  clk names
i  set   SD1_CD_B pin as CLKO1 output in devicetree
what clock should i use   to configure  CLKO1 to ouput 24MHZ
thank you sincerely
1,128件の閲覧回数
hyoungkikim
Hi Chavira
thank you for advice
in kernel  there are 4 clk name about CLK01
i am not good at  kernel clk frame
what is the clock and clock parent ?
thank you   in advance
sincerely
#define IMX7D_CLKO1_ROOT_SRC 338
#define IMX7D_CLKO1_ROOT_CG 339
#define IMX7D_CLKO1_ROOT_DIV 340
#define IMX7D_CLKO2_ROOT_SRC 341
1,148件の閲覧回数
Chavira
Hi @hyoungkikim!
Thank you for contacting NXP Support!
You have to configure it in the device tree too using the next properties:
assigned-clocks
assigned-clock-parents
Best Regards!
Chavira
