how to compile menu.c from vs2005
charlysevajol
I just want to translate menu in french. When i click right on bootloader tree in Platform builder (vs2005) there is a build process right. but if to try i write a syntax error in .c file there is non= error in build. . c file is not considered.
Labels (2)
karina_valencia
NXP Apps Support
NXP Apps Support
Deactivated user can you help on this case?
charlysevajol
When VS is in release mode it's OK, but in debug mode menu.c (for exemple) is not compiled and log note menu.obj not find...
karina_valencia
NXP Apps Support
NXP Apps Support
Adeneo Engineering Team can  you confirm if you can help on this case?
