how to change system logo?
zhouzheng
I want change the system logo,so I change the dir android_system/out/target/product/XXX/system/framework/framework-res.apk,I change the picture and recreat the system.img,but when I start the board and wait system is boot finished,I clicked the Ui button(setting button),the console appear binder failed reply XXX,truncked pid xxx by signal 9,why?how to resolve it?
Labels (2)
harreymarchael
Last week, I wanted to change my system logo and found some helpful tips. It’s amazing how a good logo can make a big difference! If you’re thinking about a new look for your business, consider working with a local professional logo design company to create something special.
Hi zhou
this is common android procedure, one can look at android forums:
http://android.stackexchange.com/questions/27762/what-exactly-is-framework-res-apk
http://www.androidtablets.net/threads/how-to-manually-replace-framework-res-apk-on-stock-roms.43716/
zhouzheng
Thanks for your answer.
But this morning I tried to use U-disk to cover the file,instead of using adb  -the initial method. When I recompiled the file system, re-powered the board, clicked on the graphics button, the board was unlimited restart. How can I fix this problem?
Zhou
