how to build imx6sx linux system
Showing results forย
Search instead forย
Did you mean:ย
caibai
Hi:
    i don't want use yocto to build my linux image,so i get uboot and kernel source code from Freescale Public GIT .But i can't find any document to tell me how build uboot and linux kernel.
    can anyone help me?
jingyangxie
Hi,cai bai
    you can visit i.MX 6 Series Software and Development Tool|NXP ,to download https://www.nxp.com/webapp/sps/download/preDownload.jsp
(L4.1.15_1.2.0_LINUX_DOCS).In the directory,you can read i.MX_BSP_Porting_Guide.pdf
caibai
thank you for reply๏ผŒthis document is about yocto but i dont want use yocto because my computer is too old and I must task a lot of time to build itใ€‚so i want direct to build uboot and kernel.
i dont know how to get the code and how to build uboot and kernel
does it only yocto support
Hi cai
for uboot compilation oen can look at sect.1.2.1 Preparing the Code
attached  i.MX BSP Porting Guide. For linux may be useful to check
Setting up the Eclipse IDE for Yocto Application Development
caibai
jingyangxie
Hi,cai bai
I will upload the source_code in Baidu cloud,you can download from it.
link: http://pan.baidu.com/s/1bp9i415
passwd: b4vv
Good luck!
caibai
have any document tell me how to build uboot and kernel?
i want build for imx6soloX
for example
make WHATNAME_defconfig  when this commnd run in top of uboot source code dir
jingyangxie
you can read i.MX_BSP_Porting_Guide.pdf in L4.1.15_1.2.0_LINUX_DOCS
caibai
thank you for your code ,i have another question,when i run
make mx6sxsabresd_defconfig
in your uboot  code dir,it work finely,but i get uboot code from
git clone git://git.freescale.com/imx/uboot-imx.git
and then i run make mx6sxsabresd_defconfig ,it doesn't work ,where are your code from?
jingyangxie
the version you download is too low
jingyangxie
in yocto Project
