how to build imx6sx linux system
5,130 次查看
caibai
Hi:
    i don't want use yocto to build my linux image,so i get uboot and kernel source code from Freescale Public GIT .But i can't find any document to tell me how build uboot and linux kernel.
    can anyone help me?
标记 (1)
10 回复数
4,581 次查看
jingyangxie
Contributor V
Hi,cai bai
    you can visit i.MX 6 Series Software and Development Tool|NXP ,to download https://www.nxp.com/webapp/sps/download/preDownload.jsp
(L4.1.15_1.2.0_LINUX_DOCS).In the directory,you can read i.MX_BSP_Porting_Guide.pdf
4,581 次查看
caibai
thank you for reply,this document is about yocto but i dont want use yocto because my computer is too old and I must task a lot of time to build it。so i want direct to build uboot and kernel.
i dont know how to get the code and how to build uboot and kernel
does it only yocto support
4,578 次查看
igorpadykov
Hi cai
for uboot compilation oen can look at sect.1.2.1 Preparing the Code
attached  i.MX BSP Porting Guide. For linux may be useful to check
Setting up the Eclipse IDE for Yocto Application Development
4,578 次查看
caibai
4,578 次查看
jingyangxie
Contributor V
Hi,cai bai
I will upload the source_code in Baidu cloud,you can download from it.
link: http://pan.baidu.com/s/1bp9i415
passwd: b4vv
Good luck!
4,578 次查看
caibai
have any document tell me how to build uboot and kernel?
i want build for imx6soloX
for example
make WHATNAME_defconfig  when this commnd run in top of uboot source code dir
4,578 次查看
jingyangxie
Contributor V
you can read i.MX_BSP_Porting_Guide.pdf in L4.1.15_1.2.0_LINUX_DOCS
4,578 次查看
caibai
thank you for your code ,i have another question,when i run
make mx6sxsabresd_defconfig
in your uboot  code dir,it work finely,but i get uboot code from
git clone git://git.freescale.com/imx/uboot-imx.git
and then i run make mx6sxsabresd_defconfig ,it doesn't work ,where are your code from?
4,578 次查看
jingyangxie
Contributor V
the version you download is too low
4,578 次查看
jingyangxie
Contributor V
in yocto Project
