how to add vlc to yocto
3,202 次查看
fu_qiang
hi all
Does anyone know if you want to add VLC player to the yocto system of imx8? Many methods have been tried but failed.whether anyone has successfully added, if so, please help to inform, thank you
3,094 次查看
gusarambula
Hello Fu Qiang,
There is not VLC recipe available as part of the Yocto BSP release or Community BSP.
There were some efforts by third parties to integrate VLC on i:MX boards in the past (link below)
https://wiki.dh-electronics.com/index.php/Building_Chromium,_VLC_and_X11VNC_using_Yocto
However, I haven’t heard of efforts in newer layers. VLC is open source so you may write your own Yocto recipe, although this is not a trivial task.
My apologies for the inconvenience!
