how to add bluetooth in imx6q_sabresd?
2,866 次查看
weisheng
     hello,I have a imx6q_sabresd board,but there are just a bluetooth slot,what type of the bluetooth device should  I bought? Is the android-4.4.3 support bluetooth by default?if no,what should i do to make it support bluetooth?
     I am a newer,please help ,thank you!
标签 (2)
标记 (1)
2,131 次查看
Rita_Wang
Hi weisheng,
In our Android_Release_Notes.pdf  you can see that the default board support the follow :
Connectivity - BT
Hardware:
• Silex AR6233X SDIO card
And there are some useful threads you can refer to:
How to enable BT on board imx6q_sabresd RevC.
All Boards Bluetooth Dongle
USB Bluetooth Dongle not working
Hope this can help you.
Dan
2,132 次查看
Rita_Wang
Hi weisheng,
Connectivity - BT
Hardware:
Dan
2,130 次查看
weisheng
hi dan wang,
thanks for fast reply,your answer help me a lot,i am trying.
