hello,I have a imx6q_sabresd board,but there are just a bluetooth slot,what type of the bluetooth device should I bought? Is the android-4.4.3 support bluetooth by default?if no,what should i do to make it support bluetooth?
I am a newer,please help ,thank you!
已解决! 转到解答。
Hi weisheng,
In our Android_Release_Notes.pdf you can see that the default board support the follow :
Connectivity - BT
Hardware:
• Silex AR6233X SDIO card
And there are some useful threads you can refer to:
How to enable BT on board imx6q_sabresd RevC.
USB Bluetooth Dongle not working
Hope this can help you.
Dan
Hi weisheng,
Connectivity - BT
Hardware:
Dan
