how easy is it to change the UART 4 (M7 Debug) for user Appliktion on MIMX8MN6
已解决
跳至解决方案
1,754 次查看
Sal2020
Is it possible to use UART4 for other application (Not for M7 debug) without hardware changes on i.MX8M Nano?
Can I change the UART 4 for other device communication only via Software like (u-boot, Linux and systemd)?
I don't want to change UART4 as A53 debug like here I would like to stay UART 2 for A53 debug.
regards
1 解答
1,743 次查看
2 回复数
1,718 次查看
BiyongSUN
The document tells you everything. Your case is just the subset in the document.
1,744 次查看
Hi Saleem
one can look at dts example with uart4
https://github.com/digi-embedded/linux/blob/v5.4/dey-3.0/maint/arch/arm64/boot/dts/digi/ccimx8mn-dvk...
