Is it possible to use UART4 for other application (Not for M7 debug) without hardware changes on i.MX8M Nano?
Can I change the UART 4 for other device communication only via Software like (u-boot, Linux and systemd)?
I don't want to change UART4 as A53 debug like here I would like to stay UART 2 for A53 debug.
regards
Solved! Go to Solution.
Hi Saleem
one can look at dts example with uart4
The document tells you everything. Your case is just the subset in the document.
Hi Saleem
