how configure zImage-imx7d-sdb-mipi-dsi.dtb
864535720
Hello, I encountered a lot of problems in the process of transplanting mipi-dsi, so I went back and used the zimage+zImage-imx7d-sdb-mipi-dsi.dtb provided by you. I found that I can start normally, I want to I would like to ask you the configuration of dts corresponding to zImage-imx7d-sdb-mipi-dsi.dtb, it is best to analyze your source code.
thank you very much!
gusarambula
Hello 其东 刘
The source code for the device tree configuration from the BSP is available on the repositories for example on the following path for the 4.1.15 BSP:
http://git.freescale.com/git/cgit.cgi/imx/linux-imx.git/tree/arch/arm/boot/dts?h=imx_4.1.15_2.0.0_ga
I hope this information helps!
