hi Freescale,
how can we capture raw-PCM 6 channel audio from imx-6 ?
we do not even want ALSA
regards
Nagendra
Hi nagendra
yes, up to 32 time slots (channels) are supported in SSI Network Mode,
IMX6DQRM sect.61.8.1.2.2 Network Mode Receive
Figure 61-15. Network Mode Timing
thank you igor,
that should be fine, could you please share any test apps/driver to achieve the same , you can even suggest the link/sdk info etc.
regards,
Nagendra
Hi nagendra
I do not know such example, suggest to reuse ssi example from SDK
"MX6_PLATFORM_SDK "
~igor
