host msd fatfs rt1020 can't find the D: on the computer
andréluis
Hi, i use the example host msd fatfs bm in my imxrt1021 evk and when i remove the USB from the EVK and open in the computer, i can't find it anymore.
Please i need a help with the pendrive.
Thanks.
jingpan
Hi @andréluis ,
Sorry, I don't understand. What do you want to find, EVK board or SD card? Can you describe what you do to the demo step by step?
Jing
andréluis
Hello Jingpan, how are you? I did the following test: I opened the evkmimxrt1020_host_msd_fatfs_bm example and put my usb to do the pendrive test. However, after removing the pendrive from the EVK, I put it on the computer, but the pendrive does not appear in Windows. He lost the directory name. So I wanted to know if the example can return the name of the directory.
jingpan
Hi @andréluis ,
I use a 16G and a 128G USB pen drive. There's no problem. Can you try other pen drive? What is your SDK version?
Jing
andréluis
Hello, I solved the problem. I had to format the pendrive by linux because windows didn't give me conditions to do that. Regarding the pendrive, it was formatted in boot mode for linux, this may have been the problem.
