hi i am using rt1170evk board i need to interface lwip stack i gone through the ethernet example, in that evk board they provided phyrtl8211f and phyksz8081 for physical layer interface but in my application i need to use the ksz8851nsl as phy what are things needs be change (which files) where can i find the resources to understand these things better.
in below image what are the files i need go through it to understand where the data is getting input and output from lwip stack
Solved! Go to Solution.
Yes
