hi i am using rt1170evk board i gone through the ethernet example, in that evk board they provided p
sandeep_c
hi i am using rt1170evk board i need to interface lwip stack i gone through the ethernet example, in that evk board they provided phyrtl8211f and phyksz8081 for physical layer interface but in my application i need to use the ksz8851nsl as phy what are things needs be change (which files) where can i find the resources to understand these things better.
in below image what are the files i need go through it to understand where the data is getting input and output from lwip stack
jingpan
jingpan
Hi, @sandeep_c ,
Please modify the .c/.h file in component/phy.
jing
sandeep_c
Thank you for reply
you mean under the phy folder rtl8211f.c and .h files right?
as you mentioned i didn't found any folder like phy under component in the example of enent ping
jingpan
Yes
sandeep_c
THANK YOU FOR REPLY
