help on how to explore the pinpong module APIs to communicate between cores (A9 and M4) with( kernel module to user module) middle ware or applications layer
1,686 次查看
anilchowdary
Hi All,
need help on how to explore the pinpong module communication between cores (A9 and M4) with middle ware or applications layer.
Known thing is: now communication is happening between cores (A9 and M4) by RPMsg examples (with the imx_pingpong.ko and freeRTOS pingpong application).
TODO: by using imx_pingpong.ko (A9 side) how we can expose the pinpong module header-files(rpmsg.h) and APIs to middle ware or application layer( or user level) A9 side. please provide any approach or some examples ( kernel module to user module) if you have already done.
Thanks For your valuable support.
-Anil
标签 (3)
1,458 次查看
PetrL
in case you are looking for exposing RPMSG endpoint to Linux userspace please look at following GitHUB project GitHub - NXPmicro/rpmsg-sysfs: Linux sysfs interface for RPMsg      .
PetrL
1,458 次查看
anilchowdary
Thanks Petr,
the above link will helps a lot. thank you so much.
-Anil
1,458 次查看
joanxie
https://community.nxp.com/docs/DOC-333803
hope this document is helpful for you.
